Guys,
I made some extensions to the GPainter class for the 3.6" BW 128x64 screen.
If someone wants to add to this, just post a msg with your extension method.
Feel free to use in any way you like.
Gus, shall I add this to code.tinyclr.com ?
Usage:
GPainterExtensions paint = new GPainterExtensions();
paint.PrintCentered(0, 30, "Fez Rules"));
Class GPainterExtensions
namespace GHIElectronics.Graphics.Simple128x64
class GPainterExtensions : GHIElectronics.Graphics.Simple128x64.GPainter
/// <summary>
/// Clears the text that was previously printed with print.
/// </summary>
/// <param name="x"></param>
/// <param name="y"></param>
/// <param name="str">Same string as print</param>
public void PrintClear(int x, int y, string str)
for (int i = 0; i < str.Length; i++)
Print(x + i * 6, y, ' ');
/// <summary>
/// Centers the text on the screen to print
/// </summary>
/// <param name="x">Not used</param>
/// <param name="str"></param>
public void PrintCentered(int x, int y, string str)
Print(64 - (str.Length * 6) + ((str.Length * 6) / 2) + (i * 6), y, str[i]);
/// <summary>
/// Clears the previously printed centered text
/// </summary>
public void PrintCenteredClear(int x, int y, string str)
/// <summary>
/// Prints right aligned (so x is the sting's end position)
/// </summary>
public void PrintRightAligned(int x, int y, string str)
Print(x - (((str.Length) * 6) - (i * 6)), y, str[i]);
/// <summary>
/// Clears the previously right aligned text
/// </summary>
public void PrintRightAlignedClear(int x, int y, string str)
Print(x - (((str.Length) * 6) - (i * 6)), y, ' ');
/// <summary>
/// Print small right aligned (so x is the string's end position)
/// </summary>
public void PrintSmallRightAligned(int x, int y, string str)
PrintSmall(x - (((str.Length) * 4) - (i * 4)), y, str[i]);
/// <summary>
/// </summary>
public void PrintSmallRightAlignedClear(int x, int y, string str)
PrintSmall(x - (((str.Length) * 4) - (i * 4)), y, ' ');
