Good webserver example
Hello
I’m searching for a good webserver example for Hydra.
I found some codes, but using J11D and not ENC28.
Where I can found this example?
Thank you
Never tried it but both should be identical, no?
Hydra is a gadgeteer…
so maybe you can start playing with the Gadgeteer examples you can find, they should all be compatible…
I don’t have a Hydra but I believe you need to flash it with a version of the firmware that supports networking, after which the code ought to be more or less the same as it would be on the Spider. If that’s true, Simon Monk’s Getting Started with .NET Gadgeteer book has some downloadable sample programs [here] that include a couple of webserver examples, may need a bit of a tweak for Hydra but I’m sure at the very least they’d give some clue about the syntax to use.
