Sorry Problem Solved,
It was an issue with outdated references I have solved the problem by replacing the reference GHIElectronics.NETMF.Hardware v4.1.5.0 with GHIElectronics.NETMF.Hardware v4.1.8.
Cheers,
Chris
I am having problem initialising a Serial port on the Fez Cobra. I am using Glide and I’m constantly getting the error about unreferenced assemblies. The problem I have is that they are reference and they are the correct versions I know that somewhere one of the references is wrong but I can’t figure it out.
Here is a snippit of the code I’m using:
using GHIElectronics.NETMF.Glide;
using GHIElectronics.NETMF.Glide.Display;
using GHIElectronics.NETMF.Glide.UI;
//using GHIElectronics.NETMF.IO;
//using GHIElectronics.NETMF.System;
using Microsoft.SPOT.IO;
using Microsoft.SPOT.Input;
using System.IO.Ports;
using System.IO;
using System.Text;
static SerialPort SUB_UART;
// Load the windows
windows[0] = GlideLoader.LoadWindow(Resources.GetString(Resources.StringResources.LogoWindow));
windows[1] = GlideLoader.LoadWindow(Resources.GetString(Resources.StringResources.MainWindow));
windows[2] = GlideLoader.LoadWindow(Resources.GetString(Resources.StringResources.DigitalValuesWindow));
windows[3] = GlideLoader.LoadWindow(Resources.GetString(Resources.StringResources.AnalogValueWindow));
windows[4] = GlideLoader.LoadWindow(Resources.GetString(Resources.StringResources.InfoWindow));
windows[5] = GlideLoader.LoadWindow(Resources.GetString(Resources.StringResources.HelpWindow));
// Activate touch
GlideTouch.Initialize();
// Initialize the windows.
LogoWin(windows[0]);
MainWin(windows[1]);
Values_Win(windows[2]);
Values_Win(windows[3]);
Info_Win(windows[4]);
Help_Win(windows[5]);
//updateButtons();
// Assigning a window to MainWindow flushes it to the screen.
// This also starts event handling on the window.
Glide.MainWindow = windows[index];
Piezo("open");
Thread.Sleep(2000);
if (index == 0) //make sure not skipped
index++;
TimerThread = new Thread(timer_Thread);
TimerThread.Start();
Thread.Sleep(-1);
SUB_UART = new SerialPort("COM4", 9600);
SUB_UART.Open();
SUB_UART.DataReceived += new SerialDataReceivedEventHandler(Sub_Port_Recieve);
the error I get from the output is:
Invalid native checksum: GHIElectronics.NETMF.Hardware 0x9C770BE2!=0xF68F37DF
Resolving.
Assembly: FEZ Cobra Window Application (1.0.0.0) needs assembly ‘Microsoft.SPOT.Hardware.SerialPort’ (4.1.2821.0)
Error: a3000000
Waiting for debug commands…
Now I understand that it wants a reference to ‘Microsoft.SPOT.Hardware.SerialPort’ the problem is this isn’t possible ‘Microsoft.SPOT.Hardware.SerialPort’ is under the class of System.IO.Ports is this a problem with GHIElectronics.NETMF.Hardware v4.1.5.0 ?
Any help is very much appreciated.
Cheers,
Chris
