Glide loading screen
Is there a way to replace the existing LOADING screen used by Glide when your application starts up other than getting the source and modifying it?
I’d like to show a splash screen as it loads to give something nicer to look at than just the word “LOADING”
@ Dave McLaughlin - Unfortunately, not really. You could quickly draw it as the first thing in Main(), but you will still see the original version flash quickly. For reference, the loading screen is drawn on line 50, 51, and 52 in Glide.cs (last lines of the static constructor).
If you grab the source and include the project as a reference instead of using the GHI.Glide library you can remove/replace the resource in the project.
