I am trying to implement a Dropdown (i.e. ComboBox) in Glide, but instead of supplying an XML file, I am handcrafting the objects on the page.
I am getting an exception when I pass try and instantiate the ‘list’
Hardcoded way of adding dropdown list items…
<Glide Version="x.x.x">
<Window Name="window" Width="320" Height="240" BackColor="dce3e7">
<Dropdown Name="dropdown" X="100" Y="104" Width="120" Height="32" Alpha="255" Text="Select:" Font="4" FontColor="000000">
<Option Value="Data0">Label0</Option>
<Option Value="Data1">Label1</Option>
<Option Value="Data2">Label2</Option>
<Option Value="Data3">Label3</Option>
<Option Value="Data4">Label4</Option>
<Option Value="Data5">Label5</Option>
<Option Value="Data6">Label6</Option>
<Option Value="Data7">Label7</Option>
<Option Value="Data8">Label8</Option>
<Option Value="Data9">Label9</Option>
</Dropdown>
</Window>
</Glide>
GHI Library example code using XML
using GHIElectronics.NETMF.Glide;
using GHIElectronics.NETMF.Glide.Display;
using GHIElectronics.NETMF.Glide.UI;
namespace Test
// This will hold the main window.
static Window window;
// This will hold our dropdown's list.
static List list = null;
// Load the window
window = GlideLoader.LoadWindow(Resources.GetString(Resources.StringResources.Window));
// Activate touch
GlideTouch.Initialize();
// Initialize the window.
InitWin();
// Assigning a window to MainWindow flushes it to the screen.
// This also starts event handling on the window.
Glide.MainWindow = window;
Thread.Sleep(-1);
static void InitWin()
// Get the Dropdown
Dropdown dropdown = (Dropdown)window.GetChildByName("dropdown");
dropdown.TapEvent += new OnTap(dropdown_TapEvent);
dropdown.ValueChangedEvent += new OnValueChanged(dropdown_ValueChangedEvent);
// Create the list that the Dropdown uses...
list = new List(dropdown.Options, 150);
list.CloseEvent += new OnClose(list_CloseEvent);
// When the Dropdown is tapped it will open it's list.
static void dropdown_TapEvent(object sender)
Glide.OpenList(sender, list);
// This shows when the Dropdown's value changes.
static void dropdown_ValueChangedEvent(object sender)
Dropdown dropdown = (Dropdown)sender;
Debug.Print("Dropdown value: " + dropdown.Text + " : " + dropdown.Value.ToString());
static void list_CloseEvent(object sender)
Glide.CloseList();
My handcrafted variant on the above example - that is generating an exception
ListOptions mListOptions;
Dropdown mDropdown;
int x = 10;
int w = 250; //must be > 100 and lesst than LCD width
int h = 30;
int y = 10;
mListOptions = new ArrayList();
mDropdown = new Dropdown("dropdown_list",255, x, y, w, h);
for (int k = 0; k < 5; k++)
ListItem a = new ListItem("Label"+k.ToString(), "myVal"+k.ToString());
mDropdown.Options.Add(a);
mDropdown.TapEvent += new OnTap(Dropdown_TapEvent);
mDropdown.ValueChangedEvent += new OnValueChanged(Dropdown_ValueChangedEvent);
mDropdown.Text = "Select...";
mList = new List(mDropdown.Options, 150); // <<<<<<<<<<<<<<<<<<<<<<Exception Here
mList.CloseEvent += new OnClose(List_CloseEvent);
My Exception is:
An unhandled exception of type ‘System.InvalidCastException’ occurred in GHIElectronics.NETMF.Glide.dll
The mDropdown.Options is populated with 5 items and teh label and value are alos populated.
Any ideas?
