Glide for NETFM 4.2?
The one that isnt working is the one that I posted above. here is one that is working
using GHIElectronics.NETMF.Glide;
using GHIElectronics.NETMF.Glide.Display;
using GHIElectronics.NETMF.Glide.UI;
namespace Test
        // This will hold the main window.
        static Window window;
            // Load the window
            string xml;
         xml = "<Glide Version=\"" + Glide.Version + "\">";
  xml += "<Window Name=\"window\" Width=\"320\" Height=\"240\" BackColor=\"ffff28\">";
    xml += "<TextBlock Name=\"textBlock\" X=\"40\" Y=\"40\" Width=\"50\" Height=\"32\" Alpha=\"255\" Text=\"Login\" TextAlign=\"Right\" TextVerticalAlign=\"Middle\" Font=\"4\" FontColor=\"000000\"/>";
    xml += "<TextBlock Name=\"emailTxt\" X=\"40\" Y=\"72\" Width=\"75\" Height=\"32\" Alpha=\"255\" Text=\"Email\" TextAlign=\"Right\" TextVerticalAlign=\"Middle\" Font=\"2\" FontColor=\"000000\"/>";
    xml += "<TextBlock Name=\"passTxt\" X=\"40\" Y=\"109\" Width=\"75\" Height=\"32\" Alpha=\"255\" Text=\"Password\" TextAlign=\"Right\" TextVerticalAlign=\"Middle\" Font=\"2\" FontColor=\"000000\"/>";
    xml += "<TextBox Name=\"emailTxt\" X=\"125\" Y=\"72\" Width=\"150\" Height=\"32\" Alpha=\"255\" Text=\"\" TextAlign=\"Left\" Font=\"2\" FontColor=\"000000\"/>";
    xml += "<TextBox Name=\"passTxt\" X=\"125\" Y=\"109\" Width=\"150\" Height=\"32\" Alpha=\"255\" Text=\"\" TextAlign=\"Left\" Font=\"4\" FontColor=\"000000\"/>";
    xml += "<Button Name=\"loginBtn\" X=\"125\" Y=\"160\" Width=\"150\" Height=\"32\" Alpha=\"255\" Text=\"Login\" Font=\"2\" FontColor=\"000000\" DisabledFontColor=\"808080\" TintColor=\"000000\" TintAmount=\"0\"/>";
    xml += "<TextBlock Name=\"titleTxt\" X=\"0\" Y=\"0\" Width=\"320\" Height=\"32\" Alpha=\"255\" Text=\"Canvas Example\" TextAlign=\"Center\" TextVerticalAlign=\"Middle\" Font=\"4\" FontColor=\"0000FF\"/>";
    xml += "</Window>";
    xml += "</Glide>";
    // Resize any loaded Window to the LCD's size.
    Glide.FitToScreen = true;
    // Load the Window XML string.
    window = GlideLoader.LoadWindow(xml);
            // Activate touch
            GlideTouch.Initialize();
            // Initialize the window.
            InitWin();
            // Assigning a window to MainWindow flushes it to the screen.
            // This also starts event handling on the window.
            Glide.MainWindow = window;
            Thread.Sleep(-1);
        static void InitWin()
            // Create a Canvas
            // The Canvas object has no parameters as it's only used to issue draw commands when rendered.
            Canvas canvas = new Canvas();
            window.AddChild(canvas);
            // Draw a separator line.
            canvas.DrawLine(Colors.Blue, 1, 0, 32, window.Width, 32);
            // Draw a fieldset around our "Login" text block.
            TextBlock textBlock = (TextBlock)window.GetChildByName("textBlock");
            canvas.DrawFieldset(textBlock, 10, 200, 150, Colors.DarkGray, 1);
The other one is missing some fluff at the bottom.
Ah yes sorry! here is the one that isnt working in its entirety
namespace Test
        private static Window window;
        // Data Grid
        static DataGrid dataGrid;
            // Load the window
            string xml;
  xml += "<Window Name=\"window\" Width=\"320\" Height=\"240\" BackColor=\"dce3e7\">";
    xml += "<DataGrid Name=\"dataGrid\" X=\"5\" Y=\"5\" Width=\"310\" Height=\"150\" Alpha=\"255\" Font=\"4\" RowCount=\"5\" RowHeight=\"30\" Draggable=\"True\" TappableCells=\"True\" SortableHeaders=\"True\" ShowHeaders=\"True\" ShowScrollbar=\"True\" ScrollbarWidth=\"5\" HeadersBackColor=\"707476\" HeadersFontColor=\"FFFFFF\" ItemsBackColor=\"FFFFFF\" ItemsAltBackColor=\"F4F4F4\" ItemsFontColor=\"000000\" SelectedItemBackColor=\"FFF299\" SelectedItemFontColor=\"000000\" GridColor=\"BFC5C9\" ScrollbarBackColor=\"C0C0C0\" ScrollbarScrubberColor=\"000000\"/>";
   xml +=  "<TextBlock Name=\"textBlock1\" X=\"5\" Y=\"160\"Width=\"50\" Height=\"32\" Alpha=\"255\" Text=\"Scroll\" TextAlign=\"Right\" TextVerticalAlign=\"Middle\" Font=\"3\" FontColor=\"000000\"/>";
   xml += "<TextBlock Name=\"textBlock2\" X=\"5\" Y=\"202\" Width=\"50\" Height=\"32\" Alpha=\"255\" Text=\"Select\" TextAlign=\"Right\" TextVerticalAlign=\"Middle\" Font=\"3\" FontColor=\"000000\"/>";
    xml += "<TextBlock Name=\"textBlock3\" X=\"175\" Y=\"160\" Width=\"40\" Height=\"32\" Alpha=\"255\" Text=\"List\" TextAlign=\"Right\" TextVerticalAlign=\"Middle\" Font=\"3\" FontColor=\"000000\"/>";
    xml += "<Button Name=\"scrollUpBtn\" X=\"60\" Y=\"160\" Width=\"45\" Height=\"32\" Alpha=\"255\" Text=\"Up\" Font=\"3\" FontColor=\"000000\" DisabledFontColor=\"808080\" TintColor=\"000000\" TintAmount=\"0\">";
    xml += "<Button Name=\"scrollDownBtn\" X=\"110\" Y=\"160\" Width=\"60\" Height=\"32\" Alpha=\"255\" Text=\"Down\" Font=\"3\" FontColor=\"000000\" DisabledFontColor=\"808080\" TintColor=\"000000\" TintAmount=\"0\"/>";
    xml += "<Button Name=\"selectUpBtn\" X=\"60\" Y=\"202\" Width=\"45\" Height=\"32\" Alpha=\"255\" Text=\"Up\" Font=\"3\" FontColor=\"000000\" DisabledFontColor=\"808080\" TintColor=\"000000\" TintAmount=\"0\"/>";
    xml += "<Button Name=\"selectDownBtn\" X=\"110\" Y=\"202\" Width=\"60\" Height=\"32\" Alpha=\"255\" Text=\"Down\" Font=\"3\" FontColor=\"000000\" DisabledFontColor=\"808080\" TintColor=\"000000\" TintAmount=\"0\"/>";
    xml += "<Button Name=\"selectClearBtn\" X=\"175\" Y=\"202\" Width=\"50\" Height=\"32\" Alpha=\"255\" Text=\"Clear\" Font=\"3\" FontColor=\"000000\" DisabledFontColor=\"808080\" TintColor=\"000000\" TintAmount=\"0\"/>";
    xml += "<Button Name=\"selectDeleteBtn\" X=\"230\" Y=\"202\" Width=\"70\" Height=\"32\" Alpha=\"255\" Text=\"Delete\" Font=\"3\" FontColor=\"000000\" DisabledFontColor=\"808080\" TintColor=\"000000\" TintAmount=\"0\"/>";
    xml += "<Button Name=\"clearBtn\" X=\"220\" Y=\"160\" Width=\"50\" Height=\"32\" Alpha=\"255\" Text=\"Clear\" Font=\"3\" FontColor=\"000000\" DisabledFontColor=\"808080\" TintColor=\"000000\" TintAmount=\"0\"/>";
    xml += "<Button Name=\"fillBtn\" X=\"275\" Y=\"160\" Width=\"40\" Height=\"32\" Alpha=\"255\" Text=\"Fill\" Font=\"3\" FontColor=\"000000\" DisabledFontColor=\"808080\" TintColor=\"000000\" TintAmount=\"0\"/>";
  xml += "</Window>";
xml += "</Glide>";
            // Activate touch
            InitWin();
            Thread.Sleep(-1);
            // Setup the dataGrid reference.
            dataGrid = (DataGrid)window.GetChildByName("dataGrid");
            // Possible configurations...
            //dataGrid.ShowHeaders = false;
            //dataGrid.SortableHeaders = false;
            //dataGrid.TappableCells = false;
            //dataGrid.Draggable = false;
            //dataGrid.ShowScrollbar = false;
            //dataGrid.ScrollbarWidth = 4;
            // Listen for tap cell events.
            dataGrid.TapCellEvent += new OnTapCell(dataGrid_TapCellEvent);
            // Create our three columns.
            dataGrid.AddColumn(new DataGridColumn("ID", 50));
            dataGrid.AddColumn(new DataGridColumn("First Name", 125));
            dataGrid.AddColumn(new DataGridColumn("Last Name", 125));
            // Populate the data grid with random data.
            Populate(false);
            // Add the data grid to the window before rendering it.
            window.AddChild(dataGrid);
            dataGrid.Render();
            // Setup the button controls.
            Button scrollUpBtn = (Button)window.GetChildByName("scrollUpBtn");
            scrollUpBtn.TapEvent += new OnTap(scrollUpBtn_TapEvent);
            Button scrollDownBtn = (Button)window.GetChildByName("scrollDownBtn");
            scrollDownBtn.TapEvent += new OnTap(scrollDownBtn_TapEvent);
            Button selectUpBtn = (Button)window.GetChildByName("selectUpBtn");
            selectUpBtn.TapEvent += new OnTap(selectUpBtn_TapEvent);
            Button selectDownBtn = (Button)window.GetChildByName("selectDownBtn");
            selectDownBtn.TapEvent += new OnTap(selectDownBtn_TapEvent);
            Button selectClearBtn = (Button)window.GetChildByName("selectClearBtn");
            selectClearBtn.TapEvent += new OnTap(selectClearBtn_TapEvent);
            Button selectDeleteBtn = (Button)window.GetChildByName("selectDeleteBtn");
            selectDeleteBtn.TapEvent += new OnTap(selectDeleteBtn_TapEvent);
            Button clearBtn = (Button)window.GetChildByName("clearBtn");
            clearBtn.TapEvent += new OnTap(clearBtn_TapEvent);
            Button fillBtn = (Button)window.GetChildByName("fillBtn");
            fillBtn.TapEvent += new OnTap(fillBtn_TapEvent);
        static void Populate(bool invalidate)
            // Add items with random data
            for (int i = 0; i < 20; i++)
                // DataGridItems must contain an object array whose length matches the number of columns.
                dataGrid.AddItem(new DataGridItem(new object[3] { i, RandomString(10), RandomString(10) }));
            if (invalidate)
                dataGrid.Invalidate();
        static void dataGrid_TapCellEvent(object sender, TapCellEventArgs args)
            // Get the data from the row we tapped.
            object[] data = dataGrid.GetRowData(args.RowIndex);
            if (data != null)
                GlideUtils.Debug.Print("GetRowData[" + args.RowIndex + "] = ", data);
        static void scrollUpBtn_TapEvent(object sender)
            dataGrid.ScrollUp(1);
        static void scrollDownBtn_TapEvent(object sender)
            dataGrid.ScrollDown(1);
        static void selectUpBtn_TapEvent(object sender)
            if (dataGrid.SelectedIndex > 0)
                dataGrid.SelectedIndex--;
        static void selectDownBtn_TapEvent(object sender)
            if (dataGrid.SelectedIndex < dataGrid.NumItems - 1)
                dataGrid.SelectedIndex++;
        static void selectClearBtn_TapEvent(object sender)
            dataGrid.SelectedIndex = -1;
        static void selectDeleteBtn_TapEvent(object sender)
            dataGrid.RemoveItemAt(dataGrid.SelectedIndex);
        static void clearBtn_TapEvent(object sender)
            dataGrid.Clear();
        static void fillBtn_TapEvent(object sender)
            Populate(true);
        // This is used to generate random strings.
        private static Random random = new Random((int)DateTime.Now.Ticks);
        private static string RandomString(int size)
            string str = String.Empty;
            double d;
            ushort u;
            char ch;
            for (int i = 0; i < size; i++)
                d = System.Math.Floor(26 * random.NextDouble() + 65);
                u = Convert.ToUInt16(d.ToString());
                ch = Convert.ToChar(u);
                str += ch;
            return str;
Maybe this will make things a bit clearer. Its from the debug output window and shows the error.
‘Microsoft.SPOT.Emulator.Sample.SampleEmulator.exe’ (Managed): Loaded ‘C:\Documents and Settings\nzcznr\My Documents\Visual Studio 2010\Projects\Data Grid Example\bin\Debug\le\Data Grid Example.exe’, Symbols loaded.
#### Exception System.Xml.XmlException - CLR_E_WRONG_INTERRUPT_TYPE (1) ####
#### Message:
#### System.Xml.XmlReader::Read [IP: 00d7] ####
#### GHIElectronics.NETMF.Glide.GlideLoader::LoadWindow [IP: 00ba] ####
#### GHIElectronics.NETMF.Glide.GlideLoader::LoadWindow [IP: 000a] ####
#### Test.Program::Main [IP: 008e] ####
A first chance exception of type ‘System.Xml.XmlException’ occurred in System.Xml.dll
An unhandled exception of type ‘System.Xml.XmlException’ occurred in System.Xml.dll
The program ‘[4808] Micro Framework application: Managed’ has exited with code 0 (0x0).
It’s because your xml is duff.
First textbox your missing a space and one of your buttons is missing a closing /
should be
xml += "<TextBlock Name=\"textBlock1\" X=\"5\" Y=\"160\" Width=\"50\"
and
should be
xml += "<Button Name=\"scrollUpBtn\" X=\"60\" Y=\"160\" Width=\"45\" Height=\"32\" Alpha=\"255\" Text=\"Up\" Font=\"3\" FontColor=\"000000\" DisabledFontColor=\"808080\" TintColor=\"000000\" TintAmount=\"0\"/>";
Ahhh I see. A bit red faced. Thanks Justin!
Your welcome mate, my face is usually red as well :smiley:
Thank you ruimsimao & Nubiarn, this thread saved me. I’ve been banging my head against this Check hardware error off and on for weeks, my problem appears solved and I can continue my work.
