Sorry for asking but I’m new to FEZ Panda II. I suppose I have to add a reference to a FEZ Connect (driver) library in my VST project? If yes, what is the library (assemblies)? To display info on the FEZ Touch do i need somethiong like Skewworks or does the GHI provided namespace(s) have the necessary widgets?
@ gdillen
As Brett said: the FEZ Touch “driver” is only a C# class that provides an interface to the FEZ Touch device. It’s not compiled into a DLL or library, so it needs to be copied to your project.
You should download the sample VS project included with the “driver”, and study all the code in that project so you can learn how the “driver” is used in an application.
