Glide DataGrid: Is there a way to select individual cells?
I am working on a project in C# where I need to navigate a DataGrid through the use of directional keys and a numeric keypad (and NO touchscreen :’( ). There is an enter button which I am using to activate what I call “Edit DataGrid Mode”, where I call the following on the DataGrid myGrid (which selects row 10, for example, and colors it yellow):
Problem is, I would like to be able to enter into a “Edit Cell Mode” when I click the enter button again, but in the DataGrid class, there doesn’t seem to be any way to show a cell is selected. I thought about using a popup window that would get the data from the cell and then proceed from there, but I would rather avoid popups in favor of a more streamlined approach. Am I missing something about how I could trigger touch events to make a cell select? Or should I just go the hardcore route and use something similar to [code=cs]window.Graphics.DrawTextInRect(…); [/code
to make a text rectangle appear over the cell I am editing?
You have access to the source so you could potentially add the feature you need.
The datagrid for me only allows me to select a whole line and I then open an edit window to show the contents of each cell for editing. I can see you need for cell by cell though and you may need to develop this as an add on to the existing datagrid.
Thanks for the reply Dave, time to put on my thinking hat :wink:
