Coming from a defense + automation OEM /SCADA GUI background I’ve used them extensively for options, where I need to FIT many square type buttons in grid fashion on the Screen at the same time. Such that Line 1 refers to PLANT AREA, line 2 EQUIPMENT CLASS, etc, Tooltips on FEZ Cobra touchscreen ? without a mouse? This justification is getting off topic.
In short, I have a need for multi-line text on butttons, just need to offer a ‘\n’ as a line separator in the existing ‘.Text’ methods, if Glide was to be extended.
you could use a textblock as a button painting the background on a touch down, or use a button and write the multiline text yourself. you do this by overriding the render method.
One cool thing I did was to add a C# Winforms project to my solution to mock up the screens I intend to use on the FEZ Cobra. Works really well. If I was doing this alot (which I am not) I might write a tool to convert C# Winforms designer code into code to draw FEZ Glide windows.
