Hello.
Is the Hydra board compatible with Glide?
Welcome!
Yes, you can use Glide on Hydra.
If I make a new gadgeteer project without glide library used and referenced, i can deploy on my board.
when I add the reference to the Glide library into my project and try to debug , i receive an error in the output window : “An error has occurred: please check your hardware”
i’m using an hydra board and a T35 display…
Check this thread and the demo link by devhammer
@ damhold
Usually, if I see that error message, it indicates that my board is either not plugged in, or I didn’t plug it in quickly enough before starting the deployment. Have you tried a rebuild and redeploy? And are you able to ping the board from MFDeploy?
I will check this thread…
thank you
@ devhammer
Yes i can ping my board with mfdeploy !
the release date of the hydra is 6 jan 2012 ( i think the last one… )
if i remove the glide dll from project references, i can deploy
if i put add the glide dll, not…
I made a repair install of OSH sdk and i don’t have the problem anymore!!!
I just installed the last sdk yesterday… i don’t know why it was already corrupted???
Thanks a lot for the help…
@ damhold
Glad to hear you got it working!
