Another noob question: I am still trying to learn how to navigate and use classes in libraries that already exist. I find an example but then it takes a long time before I find the correct libraries (references) to add to the code.
Example:
This reference is added in my current project in Visual C#: GHIElectronics.OSH.NETMF.Hardware
In Visual C# Express, Under Project properties, Application, the value of Target framework was set to ‘.NET Micro Framework 4.1’ because I am still working with a FEZ Panda I.
Changing the Target framework from 4.1 to 4.2 .NET Micro Framework changes the list of references that are available in code.
OK, so let me get this straight, you’re using a Fez Panda? If so, then you do NOT need (and in fact, cannot use) the Open Source Hardware components. The Panda is a PREMIUM 4.1 device, so you only need the PREMIUM libraries. If you try to use the 4.1 OSHW libraries, you’ll get into trouble.
