the Capacitors are only there to filter the large power consumption that some cards seem to cause - so this won’t negatively affect any other cards, and should only positively affect this one.
Unfortunately i didn’t have a 10uF capacitor so i added 47uF in paralle with C10. The result is slightly different from previous:
As you can see the program received a different exception and managed to read the root dir. If however i insert this card with any files on it, i get the same exception in PersistentStorage class ctr as before. I’m no hardware guy so any help would be appriciated
Ok this would explain the exception when the SD card is empty. That exception as you wrote is harmless but it’s good to know why it occurs. I modified the code to avoid the exception:
RemovableMedia.Insert += (s, e) =>
if (e.Volume.IsFormatted)
Debug.Print(e.Volume.RootDirectory);
foreach (var dir in Directory.GetDirectories(e.Volume.RootDirectory))
Debug.Print(dir + "\\");
foreach (var file in Directory.GetFiles(e.Volume.RootDirectory))
Debug.Print(file);
Debug.Print("SD card not formatted");
Debug.Print("Please insert SD card...");
while (!PersistentStorage.DetectSDCard())
Thread.Sleep(1000);
Debug.Print("SD card detected");
using (var sd = new PersistentStorage("SD"))
sd.MountFileSystem();
Unfortunately the first exception that is being thrown in PersistentStorage ctor still occurs. The SD card inserted needs to have at least one file on it however !!!
I have the same result when running this code on Cobra. If the card is empty i get the exception also but I assume this is because i didn’t add any extra capacitor as i did with Domino.
