GHI.Usb.Host Controller. Curious about using Controller.Reset();
I am using a G130E Dev Board 1.2
using GHI.Usb.Host Controller
//Outside of Main()
Controller.DeviceConnectFailed += Controller_DeviceConnectFailed;
Controller.KeyboardConnected += Controller_KeyboardConnected;
Controller.Start();
// I do not get key press events unless I use the Reset() ?
// I can use Reset either before or after Controller.Start()
// and I get the same results;
Controller.Reset();
private static void Controller_KeyboardConnected(object sender, Keyboard keyboard)
	keyboard.Disconnected += keyboard_Disconnected;
	//Key press events
	keyboard.KeyDown += keyboard_KeyDown;
	keyboard.KeyUp += keyboard_KeyUp;
I do not receive events
keyboard_KeyDown or keyboard_KeyUp
unless I use Controller.Reset();
I had no idea this was necessary.
Does anyone know why?
@ willgeorge -
Are you using G120E?
I am not sure because you didn’t push all code. Here is my simple code and tested on 3 keyboards: Accer, Microsoft, Logitech K120. they all working well.
using GHI.Usb;
using GHI.Usb.Host;
using GHI.Pins;
namespace TestUSBHost_keyboard
        static OutputPort led = new OutputPort(G120E.Gpio.P3_27, true);
        static InputPort button = new InputPort(G120E.Gpio.P0_22, false, Port.ResistorMode.PullUp);
        public static void InitUSBKeyboard()
            Controller.Start();
        static void Controller_DeviceConnectFailed(object sender, EventArgs e)
            Debug.Print("Device connected failed!");
            while (button.Read() == true)
                Thread.Sleep(100);
                led.Write(!led.Read());
            InitUSBKeyboard();
            Debug.Print("USB Host inited");
            Thread.Sleep(-1);
            Debug.Print("Device connected!");
            //Key press events
        static void keyboard_KeyUp(Keyboard sender, Keyboard.KeyboardEventArgs args)
            Debug.Print("Up: " + args.ASCII);
        static void keyboard_KeyDown(Keyboard sender, Keyboard.KeyboardEventArgs args)
            Debug.Print( "Down: " + args.ASCII);
        static void keyboard_Disconnected(BaseDevice sender, EventArgs e)
            Debug.Print("Device disconnected.");
@ Dat -
Thanks much… I will try your code and see what happens.
(Though I cannot do it today)
I was using a G120E Dev Board 1.2
The keyboards worked but I only got the key press events if I used the reset first.
@ willgeorge -
Problem is in my code, I didn’t use reset function.
