I am used to using eclipse, which typically allows someone to write code like this:
* This function will add a username to the database.
* @ var userName - The username to add
* @ return - True if the username was successfully added, otherwise false
public boolean addUser(String userName) {
//I dont need to look at the function internals, I can simply look at the
//block of comments above to see if it is the function I want to use or not.
However, these blocks of comments (inline documentation) seem to be non-existent or more likely- somewhere I am not used to looking. How can I find the documentation per-function. I am specifically interested in Gadgeteer.Modules.GHIElectronics.SerCam for the FEZ Cobra II (wifi) mainboard.
I have tried looking on msdn (microsoft documentation site), tinyclr, and ghielectronics.com; no luck!
