Thanks GHI.
I received the E-Dice today.
Now if I could only find the battery.
I know I have several somewhere!
Thanks GHI.
@ willgeorge - you can use usb
Yes, thanks much! Mine (USB Prank) arrived today as well. Neat board!
One question I had (which I can test myself, but don’t want to damage the board) is whether the USB Prank can be safely run off of a USB battery or wall wart? For anything where it’s programmed as an HID, USB is fine, but if I wanted to use the pinouts to do something else with it, there’s no microUSB jack to power it.
Just want to make sure I don’t fry it in the process of testing.
As long as it is 5v you should be fine.
@ Gus -
Yes, I know. Just one of my usual ‘side remarks’.
Still have not found where I put the batteries though…
