I think my bluetooth module is broken, because I am not getting the “+BTState=1” info.
Now I use the BaudRate and MF4.2 modified Eduardo Velloso Bluetooth.cs in my Project:
using GTI = Gadgeteer.Interfaces;
namespace Gadgeteer.Modules.Velloso
/// <summary>
/// A Bluetooth module for Microsoft .NET Gadgeteer
/// </summary>
public class Bluetooth : GTM.Module
/// <summary>
/// Direct access to Serial Port.
/// </summary>
//public Gadgeteer.Socket.SocketInterfaces.Serial serialPort;
public GTI.Serial serialPort;
private GTI.DigitalOutput reset;
private GTI.InterruptInput statusInt;
private Thread readerThread;
/// <summary>
/// Possible states of the Bluetooth module
/// </summary>
public enum BluetoothState
/// <summary>
/// Module is initializing
/// </summary>
Initializing = 0,
/// <summary>
/// Module is ready
/// </summary>
Ready = 1,
/// <summary>
/// Module is in pairing mode
/// </summary>
Inquiring = 2,
/// <summary>
/// Module is making a connection attempt
/// </summary>
Connecting = 3,
/// <summary>
/// Module is connected
/// </summary>
Connected = 4,
/// <summary>
/// Module is diconnected
/// </summary>
Disconnected = 5
// Note: A constructor summary is auto-generated by the doc builder.
/// <summary></summary>
/// <param name="socketNumber">The socket that this module is plugged in to.</param>
/// <param name="baud">The designated baud rate</param>
public Bluetooth(int socketNumber, long baud)
// This finds the Socket instance from the user-specified socket number.
// This will generate user-friendly error messages if the socket is invalid.
// If there is more than one socket on this module, then instead of "null" for the last parameter,
// put text that identifies the socket to the user (e.g. "S" if there is a socket type S)
Socket socket = Socket.GetSocket(socketNumber, true, this, null);
this.reset = new GTI.DigitalOutput(socket, Socket.Pin.Six, false, this);
this.statusInt = new GTI.InterruptInput(socket, Socket.Pin.Three, GTI.GlitchFilterMode.Off, GTI.ResistorMode.Disabled, GTI.InterruptMode.RisingAndFallingEdge, this);
this.serialPort = new GTI.Serial(socket, 38400, GTI.Serial.SerialParity.None, GTI.Serial.SerialStopBits.One, 8, GTI.Serial.HardwareFlowControl.NotRequired, this);
//this.statusInt.Interrupt += new GTI.InterruptInput.InterruptEventHandler(statusInt_Interrupt);
this.serialPort.ReadTimeout = Timeout.Infinite;
this.serialPort.Open();
Thread.Sleep(5);
this.reset.Write(true);
Thread.Sleep(5);
this.SetDeviceBaud(baud);
this.serialPort.Flush();
this.serialPort.Close();
this.serialPort.BaudRate = (int)baud;
readerThread = new Thread(new ThreadStart(runReaderThread));
readerThread.Start();
Thread.Sleep(500);
/// <summary>
/// This method sets the baud rate for the device
/// </summary>
/// <param name="baud">Designated baud rate</param>
public void SetDeviceBaud(long baud)
string cmd = string.Empty;
switch (baud)
case 9600:
cmd = "9600";
break;
case 19200:
cmd = "19200";
break;
case 38400:
cmd = "38400";
break;
case 57600:
cmd = "57600";
break;
case 115000:
cmd = "115000";
break;
case 230400:
cmd = "230400";
break;
case 460800:
cmd = "460800";
break;
default:
cmd = string.Empty;
break;
if (cmd != string.Empty)
this.serialPort.Write("\r\n+STBD=" + cmd + "\r\n");
Thread.Sleep(500);
/// <summary>
/// Hard Reset Bluetooth module
/// </summary>
public void Reset()
this.reset.Write(false);
Thread.Sleep(5);
/// <summary>
/// Gets a value that indicates whether the bluetooth connection is connected.
/// </summary>
public bool IsConnected
get
return this.statusInt.Read();
/// <summary>
/// Thread that continuously reads incoming messages from the module,
/// parses them and triggers the corresponding events.
/// </summary>
private void runReaderThread()
Debug.Print("Reader Thread");
String response = "";
while (serialPort.BytesToRead > 0)
response = response + (char)serialPort.ReadByte();
if (response.Length > 0)
Debug.Print(response);
//Check Bluetooth State Changed
if (response.IndexOf("+BTSTATE:") > -1)
string atCommand = "+BTSTATE:";
//String parsing
// Return format: +COPS:<mode>[,<format>,<oper>]
int first = response.IndexOf(atCommand) + atCommand.Length;
int last = response.IndexOf("\n", first);
int state = int.Parse(((response.Substring(first, last - first)).Trim()));
OnBluetoothStateChanged(this, (BluetoothState)state);
//Check Pin Requested
if (response.IndexOf("+INPIN") > -1)
// EDUARDO : Needs testing
OnPinRequested(this);
if (response.IndexOf("+RTINQ") > -1)
//EDUARDO: Needs testing
string atCommand = "+RTINQ=";
//String parsing
int mid = response.IndexOf(";", first);
int last = response.IndexOf("\r", first);
// Keep reading until the end of the message
while (last < 0)
string address = ((response.Substring(first, mid - first)).Trim());
string name = (response.Substring(mid+1, last-mid));
OnDeviceInquired(this, address, name);
//Debug.Print("Add: " + address + ", Name: " + name );
OnDataReceived(this, response);
Thread.Sleep(10);
#region DELEGATES AND EVENTS
#region Bluetooth State Changed
/// <summary>
/// Represents the delegate used for the <see cref="BluetoothStateChanged"/> event.
/// </summary>
/// <param name="sender">The object that raised the event.</param>
/// <param name="btState">Current state of the Bluetooth module</param>
public delegate void BluetoothStateChangedHandler(Bluetooth sender, BluetoothState btState);
/// <summary>
/// Event raised when the bluetooth module changes its state.
/// </summary>
public event BluetoothStateChangedHandler BluetoothStateChanged;
private BluetoothStateChangedHandler onBluetoothStateChanged;
/// <summary>
/// Raises the <see cref="BluetoothStateChanged"/> event.
/// </summary>
protected virtual void OnBluetoothStateChanged(Bluetooth sender, BluetoothState btState)
if (onBluetoothStateChanged == null) onBluetoothStateChanged = new BluetoothStateChangedHandler(OnBluetoothStateChanged);
if (Program.CheckAndInvoke(BluetoothStateChanged, onBluetoothStateChanged, sender, btState))
BluetoothStateChanged(sender, btState);
#endregion
#region DataReceived
/// <summary>
/// Represents the delegate used for the <see cref="DataReceived"/> event.
/// </summary>
/// <param name="data">Data received from the Bluetooth module</param>
public delegate void DataReceivedHandler(Bluetooth sender, string data);
/// <summary>
/// </summary>
public event DataReceivedHandler DataReceived;
private DataReceivedHandler onDataReceived;
/// <summary>
/// Raises the <see cref="DataReceived"/> event.
/// </summary>
/// <param name="data">Data string received by the Bluetooth module</param>
protected virtual void OnDataReceived(Bluetooth sender, string data)
if (onDataReceived == null) onDataReceived = new DataReceivedHandler(OnDataReceived);
if (Program.CheckAndInvoke(DataReceived, onDataReceived, sender, data))
DataReceived(sender, data);
#endregion
#region PinRequested
/// <summary>
/// Represents the delegate used for the <see cref="PinRequested"/> event.
/// </summary>
public delegate void PinRequestedHandler(Bluetooth sender);
/// <summary>
/// </summary>
public event PinRequestedHandler PinRequested;
private PinRequestedHandler onPinRequested;
/// <summary>
/// Raises the <see cref="PinRequested"/> event.
/// </summary>
protected virtual void OnPinRequested(Bluetooth sender)
if (onPinRequested == null) onPinRequested = new PinRequestedHandler(OnPinRequested);
if (Program.CheckAndInvoke(PinRequested, onPinRequested, sender))
PinRequested(sender);
#endregion
#endregion
#region DeviceInquired
/// <summary>
/// Represents the delegate used for the <see cref="DeviceInquired"/> event.
/// </summary>
/// <param name="macAddress">MAC Address of the inquired device</param>
/// <param name="name">Name of the inquired device</param>
public delegate void DeviceInquiredHandler(Bluetooth sender, string macAddress, string name);
/// <summary>
/// </summary>
public event DeviceInquiredHandler DeviceInquired;
private DeviceInquiredHandler onDeviceInquired;
/// <summary>
/// </summary>
protected virtual void OnDeviceInquired(Bluetooth sender, string macAddress, string name)
if (onDeviceInquired == null) onDeviceInquired = new DeviceInquiredHandler(OnDeviceInquired);
if (Program.CheckAndInvoke(DeviceInquired, onDeviceInquired, sender, macAddress, name))
DeviceInquired(sender, macAddress, name);
#endregion
private object _lock = new Object();
private Client _client;
/// <summary>
/// Sets Bluetooth module to work in Client mode.
/// </summary>
public Client ClientMode
get
lock (_lock)
if (_host != null) throw new InvalidOperationException("Cannot use both Client and Host modes for Bluetooth module");
if (_client == null) _client = new Client(this);
return _client;
private Host _host;
/// <summary>
/// Sets Bluetooth module to work in Host mode.
/// </summary>
public Host HostMode
get
lock (_lock)
if (_client != null) throw new InvalidOperationException("Cannot use both Client and Host modes for Bluetooth module");
if (_host == null) _host = new Host(this);
return _host;
/// <summary>
/// Sets the device name as seen by other devices
/// </summary>
/// <param name="name">Name of the device</param>
public void SetDeviceName(string name)
this.serialPort.Write("\r\n+STNA=" + name + "\r\n");
/// <summary>
/// Sets the PIN code for the Bluetooth module
/// </summary>
/// <param name="pinCode"></param>
public void SetPinCode(string pinCode)
this.serialPort.Write("\r\n +STPIN=" + pinCode +"\r\n");
/// <summary>
/// Client functionality for the Bluetooth module
/// </summary>
public class Client
private Bluetooth bluetooth;
internal Client(Bluetooth bluetooth)
Debug.Print("Client Mode");
this.bluetooth = bluetooth;
bluetooth.serialPort.Write("\r\n+STWMOD=0\r\n");
/// <summary>
/// Enters pairing mode
/// </summary>
public void EnterPairingMode()
Debug.Print("Enter Pairing Mode");
bluetooth.serialPort.Write("\r\n+INQ=1\r\n");
/// <summary>
/// Inputs pin code
/// </summary>
/// <param name="pinCode">Module's pin code. Default: 0000</param>
public void InputPinCode(string pinCode)
Debug.Print("Inputting pin: " + pinCode);
bluetooth.serialPort.Write("\r\n+RTPIN=" + pinCode + "\r\n");
/// <summary>
/// Closes current connection. Doesn't work yet.
/// </summary>
public void Disconnect()
Debug.Print("Disconnection is not working...");
//NOT WORKING
// Documentation states that in order to disconnect, we pull PIO0 HIGH,
// but this pin is not available in the socket... (see schematics)
/// <summary>
/// Sends data through the connection.
/// </summary>
/// <param name="message">String containing the data to be sent</param>
public void Send(string message)
Debug.Print("Sending: " + message);
bluetooth.serialPort.WriteLine(message);
/// <summary>
/// Implements the host functionality for the Bluetooth module
/// </summary>
public class Host
internal Host(Bluetooth bluetooth)
Debug.Print("Host mode");
bluetooth.serialPort.Write("\r\n+STWMOD=1\r\n");
/// <summary>
/// Starts inquiring for devices
/// </summary>
public void InquireDevice()
Debug.Print("Inquiring device");
/// <summary>
/// Makes a connection with a device using its MAC address.
/// </summary>
/// <param name="macAddress">MAC address of the device</param>
public void Connect(string macAddress)
Debug.Print("Connecting to: " + macAddress);
bluetooth.serialPort.Write("\r\n+CONN="+macAddress+"\r\n");
/// <summary>
/// Inputs the PIN code.
/// </summary>
/// <param name="pinCode">PIN code. Default 0000</param>
/// <summary>
/// Closes the current connection. Doesn't work yet.
/// </summary>
//NOT WORKING
and changed the Program.cs also and removed the bluetooth module from the designer:
using Gadgeteer.Modules.Velloso;
namespace BluetoothGadgeteer
public partial class Program
private Bluetooth bluetooth = new Bluetooth(4,38400);
private Bluetooth.Client client;
client = bluetooth.ClientMode;
bluetooth.SetDeviceName("Gadgeteer");
bluetooth.SetPinCode("1234");
bluetooth.BluetoothStateChanged += new Bluetooth.BluetoothStateChangedHandler(bluetooth_BtStateChanged);
bluetooth.DataReceived += new Bluetooth.DataReceivedHandler(bluetooth_DataReceived);
joystick.JoystickPressed += joystick_JoystickPressed;
void joystick_JoystickPressed(Joystick sender, Joystick.JoystickState state)
Debug.Print("Button pressed");
if (!bluetooth.IsConnected)
Debug.Print("Try to enter pairing mode");
bluetooth.ClientMode.EnterPairingMode();
void bluetooth_BtStateChanged(Bluetooth sender, Bluetooth.BluetoothState btState)
Debug.Print(btState.ToString());
void bluetooth_DataReceived(Bluetooth sender, string data)
Debug.Print(data);
