I was able to successfully install the entire GHI 4.2 RC3 on Win7, manually install the WinUSB driver, update Cerberus firmware to 4.2.3.2 and run apps.
However, on my XP SP3 machine, I am unable to get the WinUSB driver to successfully install.
Listed below is the log of the attempted install extracted from setupapi.log.
Any suggestions?
[2012/11/07 07:32:54 3100.519]
#-198 Command line processed: “C:\WINDOWS\system32\mmc.exe” “C:\WINDOWS\system32\devmgmt.msc”
#I060 Set selected driver.
#-019 Searching for hardware ID(s): usb\vid_1b9f&pid_0106&rev_0100,usb\vid_1b9f&pid_0106
#-018 Searching for compatible ID(s): usb\class_ff&subclass_01&prot_01,usb\class_ff&subclass_01,usb\class_ff
#I022 Found “USB\vid_1B9F&Pid_0106” in c:\program files\ghi electronics\ghi netmf usb driver set\ghi_netmf_interface\ghi_netmf_winusb.inf; Device: “GHI NETMF Debug Interface”; Driver: “GHI NETMF Debug Interface”; Provider: “GHI Electronics”; Mfg: “GHI Electronics”; Section name: “USB_Install”.
#I087 Driver node not trusted, rank changed from 0x00000001 to 0x00008001.
#I023 Actual install section: [USB_Install]. Rank: 0x00008001. Effective driver date: 09/10/2012.
#-166 Device install function: DIF_SELECTBESTCOMPATDRV.
#I063 Selected driver installs from section [USB_Install] in “c:\program files\ghi electronics\ghi netmf usb driver set\ghi_netmf_interface\ghi_netmf_winusb.inf”.
#I320 Class GUID of device remains: {36FC9E60-C465-11CF-8056-444553540000}.
#I058 Selected best compatible driver.
#-124 Doing copy-only install of “USB\VID_1B9F&PID_0106\5&19D1CE61&0&2”.
#E366 An unsigned or incorrectly signed file “c:\program files\ghi electronics\ghi netmf usb driver set\ghi_netmf_interface\ghi_netmf_winusb.cat” for driver “GHI NETMF Debug Interface” will be installed (Policy=Warn, user said ok). Error 0x800b0110: The certificate is not valid for the requested usage.
#W187 Install failed, attempting to restore original files.
#E362 An unsigned or incorrectly signed file “c:\program files\ghi electronics\ghi netmf usb driver set\ghi_netmf_interface\ghi_netmf_winusb.cat” for driver “GHI NETMF Debug Interface” will be installed (Policy=Warn). Error 0x800b0110: The certificate is not valid for the requested usage.
#-024 Copying file “c:\program files\ghi electronics\ghi netmf usb driver set\ghi_netmf_interface\WinUsbCoInstaller2.dll” to “C:\WINDOWS\system32\WinUsbCoInstaller2.dll”.
#E362 An unsigned or incorrectly signed file “c:\program files\ghi electronics\ghi netmf usb driver set\ghi_netmf_interface\WinUsbCoInstaller2.dll” for driver “GHI NETMF Debug Interface” will be installed (Policy=Warn). Error 0x800b0110: The certificate is not valid for the requested usage.
#-336 Copying file “c:\program files\ghi electronics\ghi netmf usb driver set\ghi_netmf_interface\WdfCoInstaller01011.dll” to “C:\WINDOWS\system32\WdfCoInstaller01011.dll” via temporary file “C:\WINDOWS\system32\SET60.tmp”.
#E362 An unsigned or incorrectly signed file “c:\program files\ghi electronics\ghi netmf usb driver set\ghi_netmf_interface\WdfCoInstaller01011.dll” for driver “GHI NETMF Debug Interface” will be installed (Policy=Warn). Error 0x800b0110: The certificate is not valid for the requested usage.
#-166 Device install function: DIF_REGISTER_COINSTALLERS.
#I056 Coinstallers registered.
#-148 Loading coinstaller modules for “GHI NETMF Debug Interface”.
#E144 Loading module “C:\WINDOWS\system32\WdfCoInstaller01011.dll” failed. Error 193: %1 is not a valid Win32 application.
#E144 Loading module “C:\WINDOWS\system32\WinUsbCoInstaller2.dll” failed. Error 193: %1 is not a valid Win32 application.
#-166 Device install function: DIF_INSTALLINTERFACES.
#-011 Installing section [USB_Install.Interfaces] from “c:\program files\ghi electronics\ghi netmf usb driver set\ghi_netmf_interface\ghi_netmf_winusb.inf”.
#I054 Interfaces installed.
#-166 Device install function: DIF_INSTALLDEVICE.
#I123 Doing full install of “USB\VID_1B9F&PID_0106\5&19D1CE61&0&2”.
#-035 Processing service Add/Delete section [USB_Install.Services].
#E339 Add Service: Binary “C:\WINDOWS\system32\DRIVERS\WinUSB.sys” for service “WinUsb” is not present.
#E032 Error 0xe0000217: A service installation section in this INF is invalid.
#E275 Error while installing services. Error 0xe0000217: A service installation section in this INF is invalid.
#E122 Device install failed. Error 0xe0000217: A service installation section in this INF is invalid.
#E157 Default installer failed. Error 0xe0000217: A service installation section in this INF is invalid.
#I125 Installing NULL driver for “USB\VID_1B9F&PID_0106\5&19D1CE61&0&2”.
#I121 Device install of “USB\VID_1B9F&PID_0106\5&19D1CE61&0&2” finished successfully.
