from time to time i get a sql error when i’m do a page-back from a new forum item to the “what is new” page.
[quote]Error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘’ at line 1
Query: SELECT COUNT(*) AS num_rows FROM forum_unread WHERE id_user =[/quote]
most of the time i have waited some time (reading) before i do the page-back action.
Your session seems to be timing out. When you return to the unread page it does not know your user ID so the query errors. This will be fixed by tomorrow morning.
[quote]Is this the page that’s giving you the error? http://www.tinyclr.com/forum/unread/[/quote]
Yes, that is the page. When i wait some time before i go back from bv this page to the unread page then i get above error message.
