The piece of codes below works fine for dotnetcore, but throwing exception in TinyCLR.
This is a simple code to do post http.
Let me know what went wrong, and perhaps there is work around.
try
using (var req = HttpWebRequest.Create(url) as HttpWebRequest)
req.Method = "POST";
string postData = "password=000000000000";
byte[] data = Encoding.UTF8.GetBytes(postData);
req.ContentType = "application/x-www-form-urlencoded; charset=UTF-8";
req.ContentLength = data.Length;
req.Accept = "application/json";
req.KeepAlive = true;
//req.HttpsAuthentCerts = certx509;
req.ProtocolVersion = HttpVersion.Version10;
req.ReadWriteTimeout = 2000;
Stream reqStream = req.GetRequestStream();
reqStream.Write(data, 0, data.Length);
reqStream.Close();
using (var res = req.GetResponse() as HttpWebResponse)
Debug.WriteLine("status code = " + res.StatusCode);
using (var stream = res.GetResponseStream())
do
read = stream.Read(result, 0, result.Length);
total += read;
System.Diagnostics.Debug.WriteLine("read : " + read);
System.Diagnostics.Debug.WriteLine("total : " + total);
var page = new String(System.Text.Encoding.UTF8.
GetChars(result, 0, read));
System.Diagnostics.Debug.WriteLine("Response : " + page);
while (read != 0);
catch {
This is the error:
DoTestHttps
#### Exception System.InvalidOperationException - CLR_E_INVALID_OPERATION (1) ####
#### Message:
#### GHIElectronics.TinyCLR.Devices.Network.Provider.NetworkControllerApiWrapper::AuthenticateAsClient [IP: 0000] ####
#### System.Net.Security.SslStream::AuthenticateAsClient [IP: 0016] ####
#### System.Net.Security.SslStream::AuthenticateAsClient [IP: 0009] ####
#### System.Net.Security.SslStream::AuthenticateAsClient [IP: 0008] ####
#### System.Net.Security.SslStream::AuthenticateAsClient [IP: 0006] ####
#### System.Net.HttpWebRequest::SubmitRequest [IP: 0019] ####
#### System.Net.HttpWebRequest::GetRequestStream [IP: 0008] ####
#### TinyCLRApplication.Program::Main [IP: 0128] ####
Exception thrown: âSystem.InvalidOperationExceptionâ in GHIElectronics.TinyCLR.Networking.Http.dll
