Get enum value name
Say you have an enum.
public enum MyEnum
Value1,
Value2,
Value3
Now I want to get the value name, and not the value index. I was used to do it like this:
MyEnum myenum = MyEnum.Value3;
myenum.ToString();
But this returns 2 instead of Value3. How can I get the value name in .NET Micro Framework?
Wouter, look here: [url]http://www.tinyclr.com/forum/1/1395/[/url]
I sometimes go the quick and easy route with:
public static string GetMyEnumName(MyEnum myEnum)
    Debug.Print("MyEnum Name:" + myEnum.ToString());
    switch (myEnum)
        case MyEnum.V1:
            return "V1";
        case MyEnum.V2:
            return "V2";
        case MyEnum.V3:
            return "V3";
        default:
            return "Unknown";
public enum MyEnum
    V1,
    V2,
    V3
I’ll first try the reflection method and see if it works. If it doesn’t I’ll use William’s method.
Reflection doesn’t seem to work. The only field returned is “value__”.
Going for the switch-case solution :slight_smile:
