Get Code from String
Hello Guys,
I’m working on an Menu for the N18 Display and i have a problem.
I have all the different Menu positions already in a String. And every position has it’s own method, so i need to get the text from the string and convert it to code.
Lets say:
string MenuPos1 = "MenuPos1";
string s = "();";
MenuPos1 = MenusPos1 + s;
So now the string looks like “MenuPos1();” and i now want to call this method. But i need this String in code.
void MenuPos1()
I could make a query for ever position, but i want like 20 Sub menus. So it would be way too much.
Thanks in advance
Benjamin
You can use reflection.
In my perspective this is superior programming (the last thing i programmed was a calculator;) ).
Would it be possible to make an example oriented by my given code?
@ -Encore- - You could do something like this:
// call this method with the name of the selected menu position
public void ExecuteMenu(string menuPos)
     switch (menuPos)
          case "MenuPos1":
               DoMenuPos1();
                break;
          case "MenuPos2":
               DoMenuPos2();
                break;
          case "MenuPos3":
               DoMenuPos3();
                break;
private void DoMenuPos1()
     // do menu position 1 stuff here...
private void DoMenuPos2()
     // do menu position 2 stuff here...
private void DoMenuPos3()
     // do menu position 3 stuff here...
This was my idea first, but i would need to do a very long list for every position. I thoght there was an more elegant way to do it.
Yes, I agree. A more elegant way would be to use delegates. Each DoMenuPosN method would be added to a dictionary with the “MenuPosN” as the key.
See this post by @ Architect:
https://www.ghielectronics.com/community/forum/topic?id=2080&page=1#msg21141
Hmm… i would need to rebuild the whole program. Im just going to look into reflections.
Thanks anyway.
So i looked into it and partly understood it, but if i want to try it in my program I get an error.
The Type or Namespacename “MethodInfo” couldnt be found.
Method = MenuP[selecteditem - 1];
MethodInfo mi = this.GetType().GetMethod(Method);
mi.Invoke(this, null);
Ah got it needed to add the System.Reflection namespace
Got another Error: Error invoking method “Gadgeteer.Interfaces.InterruptInput” (check arguments to Program.BeginInvoke are correct)
with this code:
            MethodInfo mi = this.GetType().GetMethod(MenuP[selecteditem - 1]);
Anyone have an idea what ths solution could be ?
EDIT: I forgot to put public in front of the Method
I got it now working.
Reflection is very neat feature and not as complicated as you have already figured out. Glad you got it working.
