Gestures on T35?
Is it possible to do the slide left/right gesture in Glide?
Using the (partial) code below, trying to slide on display on the right side going left. I always seem to get 7 for the gesture which corresponds to Left. In my tests (which I very well am be doing something wrong) it seems as if only the last touch point is being registered.
Is the Pan/zoom/etc gestures for other displays or am I missing something?
              // other code to setup the window
               Window.GestureEvent += new OnGesture(Window_GestureEvent);
        void Window_GestureEvent(object sender, TouchGestureEventArgs args)
            if (args.Gesture == TouchGesture.Pan)
                txtBlck.Text = "Pan";
                Window.Invalidate();
Pan and zoom require multitouch which t35 is not
Tom
I can see how zoom requires multi-touch, but I would think pan/swipe would only require tracking of a single touch.
That was my thinking as well.
Swipe does only require a single touch. Zoom and pan are both multitouch as defined by the API http://msdn.microsoft.com/en-us/library/ee436832.aspx
MS calls Pan a multitouch scroll option.
Thanks for that reference … I interpreted “Left” as a touch occured on the left side of the screen. The doc says “Moving left.”
For some reason I assumed Pan was swipe, as there was no “swipe” in the enumeration.
