I have an Byte array with the ascci time and I want to compare it to the current system time
and determine if its < , == , > current time. (for Cobra project) I’m sorta new to C# ???
I think teh easiest way is by converting your string to DateTime object then you can compare the ticks.
Check out [url]Microsoft Learn: Build skills that open doors in your career for the overloads you can use to create a DateTime object. You’ll obviously have to convert the byte array to integers containing the date parts.
Something like
//example date byte array
byte[] dateBytes = new byte[]{11,7,19};
int year = (int)dateBytes[0] + 2000;
int month = (int)dateBytes[1];
int day = (int)dateBytes[2];
DateTime date = new DateTime (year, month, day);
You can use operators (<, >, =, etc) to directly compare dates.
Most excellent - TNX : Ray
