Hi to everyone! I run the Gadgeteer WebServer on Fez Raptor. I am using a responder.Respond() method to send a response to windows PC client side. I use Ad-Hoc connection between PC and Raptor via WIFI RS 21 module.
Here is a code:
ProgramStarted()
WebEvent status = WebServer.SetupWebEvent("status");
status.WebEventRecived+= status_WebEventRecieved;
WebServer.StartLocalServer(ipaddress,80);
void status_WebEventRecieved(string path, WevServer.HttpMathod method, Responder responder)
byte[] data = System.Text.Encoding.UTF8.GetBytes("status");
responder.Respond(data,"text/html");
WebEvent fires with no problem on Raptor side, but client side response event handler that expects System.Net.Http.HttpResponseMessage with text/html content type never fires.
Here is Ad-Hoc connection code i use:
WiFiRS9110.NetworkParameters ACCESSPOINT_PARAMS = new WiFiRS9110.NetworkParameters();
ACCESSPOINT_PARAMS.Channel=6;
ACCESSPOINT_PARAMS.Key = "";
ACCESSPOINT_PARAMS.Ssid = "RaptorBOT";
ACCESSPOINT_PARAMS.NetworkType = WiFiRS9110.NetworkType.AdHoc;
ACCESSPOINT_PARAMS.SecurityMode = WiFiRS9110.SecurityMode.Open;
wifiRS21.NetworkInterface.Open();
wifiRS21.UseThisNetworkInterface();
wifiRS21.NetworkInterface.EnableStaticIP("192.168.0.65", "255.255.0.0", "192.168.0.65");
wifiRS21.NetworkInterface.StartAdHocNetwork(ACCESSPOINT_PARAMS);
What is the problem? Should i convert the Gadgeteer response on the client side somehow? Or Ad-hoc connection doesn’t allow to send Respond?
