Gadgeteer prototype to production device
Gadgeteer is still pretty young, but are there any success stories of a company using it to rapid prototype? If this has been the case with Panda I can only imagine gadgeteer being more accessible. I’ve been demoing some ghi stuff to my peers (we’re software not hardware) and it is generating a lot of interest.
I don’t want to misrepresent anything, so is it realistic to turn over a gadget to GHI and say ‘please turn this cerberus + gadgeteer modules into a single board’ and remove any extraneous components’? As part of a consulting engagement, of course.
[quote=“Dr9”]I don’t want to misrepresent anything, so is it realistic to turn over a gadget to GHI and say ‘please turn this cerberus + gadgeteer modules into a single board’ and remove any extraneous components’? As part of a consulting engagement, of course.
[/quote]
I’m also interested in this.
This is bapenning already and actually larger part of GHI’s business
Of course the companies won’t come here and post about it in most cases.
It might be bad form to disclose that a major Chinese missile manufacturer is using GHI Electronics to make it’s .NetMF based guidance systems that it then turns around and sells to US defense contractors at a substantial markup :slight_smile:
Uh…yea, sure.
Can you share what ‘typical’ size of run is like?
I realize pricing is wholly dependant on complexity and time. My back of the envelope numbers based on an assumed setup of about 30K and some wild guesses on wholesale hardware vs. gadgeteer retail, the number that I came up with is that if you were doing over 400 units you’re in the territory where it make sense to get ‘custom’. In addition to a smaller unit, which probably would have less power consumption (if components removed).
I don’t need a quote, but am I wildly off with my numbers?
See related question here about consulting http://www.ghielectronics.com/faq
This talks about your consulting service, which is helpful.
Does GHI do production runs as well? Or is your fancy new production equipment only for GHI retail equipment?
I’ve seen them run custom boards before.
I thought it does talk about GHI’s production but yes we can do it all even manufacturing and distribution.
