A project I was working on now displays XAML under the tab “program.gadgeteer.diagram”. What caused this to happen? Is ltheir any way to get the graphical view back?
Thanks, Bob
Double click “Program.gadgeteer” item
@ Architect -
As always you guys come through. Thank you!
Architect
I have this issue with one application. It keeps changing back to XML. Do you know what causes this?
Not an issue, just a question.
Is it you clicking the .Diagram item in the screenshot Arcitect showed; the default is that the “Program.Gadgeteer” item is open, which is the designer surface. If you collaps that object so you don’t see the .Diagram item you won’t be tempted to click it and see XML
