Has anyone been able to clean up the keypad test code?
I have made the test code work but it sporadically registers what key is pressed and occasionally when the key is pressed down it will register multiple events as stated but the key up event never appears. I was attempting to clean up the code to only show the key up event so it would only show one event per press but since this doesn’t work reliably it hasn’t been that easy…
Could it be a problem with the hardware or have others seen the same problem with the keypad?
Thanks!
