Is there any information about the minimum external components required?
Also, assuming I can get permission for the export restrictions will the same firmware work on the STM32F437? ST is headquartered in Switzerland, so it should be possible to export to my little island.
@ Mr. John Smith - like suggested, the schematic is a good start but what you need is a Crystal and 3.3V.
As for the chip, you are buying a G80 not an STM chip. The firmware is encrypted and only licensed to run on the chip you buy from us. However, if you need adifferent micro then we can handle this through our consulting services.
That might ne difficult, since you Need differnt chips for differ CAN speeds. Also some environments might “ask” for specific chips, like in the automotive sector.
