Hi, I’ve recently implemented a custom USB device using the Microsoft.SPOT.Hardware.Usb constructs following another sample I found here.
As such, I switched to serial debugging. Everything works fine until I attempt to assign the configuration to the UsbController:
usbController.Configuration = entireConfiguration;
If I step over this line with the debugger, it hangs the G80 board (Panda III), and the debugger freezes. If I reset the board (which disconnects the debugger), it works fine. If I run the board without hooking up a debugger at all, it runs fine, too.
Note: I’m using the pre-release SDK.
Any ideas what might be happening?
