Which pins are used for the currently supported USBH? The same as for USB Client?
are you looking for more information then is in this document?
http://ghielectronics.com/downloads/man/G400_D_Module_Brochure.pdf
That shows the pins for all three USB ports. The question is: did GHI use USB1 for both Host and Client, or did they use USB1 for Client, and USB2 for Host ?
I don’t have a ChipWorkX, so I’m not sure how it’s done there.
ChipworkX docs are still available, see the [em]Resource[/em] tabs on these Catalog entries:
the module: http://www.ghielectronics.com/catalog/product/123
the development system: http://www.ghielectronics.com/catalog/product/125
I looked …
ChipworkX has two Host ports. Which one is “alive” when the G400-D module is plugged in? Better still - can someone just say which pins on the G400HDR are the Host USB pins?
The USB Host port should be either port B or C. I think it is C currently.
Thanks. I’ll solder a breakout board to G400HDR USB_C and see what happens …
You’re right … it’s USB_C
Works…
@ Lurch - That is good know, thanks for sharing your findings.
