I am a new member of the community.
I am developing an interface https to a central alarm.
I currently use the mainboard Fez Cobra II, but SSL is very slow, a simple request / response that in http takes less than 1 second in https takes 5 seconds.
I would like to know how much performance would improve using a Fez Raptor.
With Fez cobra 2 an http request that return json data takes 1 second, in https the sane request takes 5 seconds.
The bottleneck seems to be SSL hadshaking and crypt/decrypt.
Would be useful a ssl speed test between g120 e g400.
I have implemented WebServer with Networking Toolkit Micro HttpServer (Michael Swartz).
When running the httpserver in SSL it works fine, but VS2012 output view displays several SocketException (probably during the SSL handshaking), is this normal? or would it be better to use HttpListener?
Having received no response from MFToolkit developer, I modified the source code of the class httpserver and now seems to work better, no exception timeout.
The only exceptions that are thrown are
SocketException ErrorCode = 5
"The certificate revocation list signature could not be decrypted."
“the CRL signature could not be decrypted: this means That the actual signature value could not be determined rather than it not matching the expected value. Unused.”
It is not a fatal error because the application works fine, but I would like to fix it.
Here is the log:
Program Started
#### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (9) ####
#### Message:
#### Microsoft.SPOT.Net.Security.SslNative::SecureAccept [IP: 0000] ####
#### Microsoft.SPOT.Net.Security.SslStream::Authenticate [IP: 0045] ####
#### Microsoft.SPOT.Net.Security.SslStream::AuthenticateAsServer [IP: 000d] ####
#### Microsoft.SPOT.Net.Security.SslStream::AuthenticateAsServer [IP: 0008] ####
#### MFToolkit.Net.Web.HttpProcessor::ProcessRequest [IP: 00be] ####
#### SocketException ErrorCode = 5
A first chance exception of type ‘System.Net.Sockets.SocketException’ occurred in Microsoft.SPOT.Net.Security.dll
#### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (10) ####
#### Message:
3 worker threads (0.0.0.0:81)
A first chance exception of type ‘System.Net.Sockets.SocketException’ occurred in System.Net.Security.dll
The thread ‘’ (0x9) has exited with code 0 (0x0).
The thread ‘’ (0xa) has exited with code 0 (0x0).
1 worker threads (0.0.0.0:81)
ProcessRequest: Request /
The thread ‘’ (0xb) has exited with code 0 (0x0).
ProcessRequest: Request /LoginPage
The thread ‘’ (0xc) has exited with code 0 (0x0).
ProcessRequest: Request /js/jquery-1.10.2.min.js
The thread ‘’ (0xd) has exited with code 0 (0x0).
