I’m using @ Taylorza Gadgeteer helper, but running code from VS2012 I get this messages:
'Microsoft.SPOT.Debugger.CorDebug.dll' (Gestito): caricato 'C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Display_TE35\NETMF 4.2\le\GTM.GHIElectronics.Display_TE35.dll', simboli caricati.
'Microsoft.SPOT.Debugger.CorDebug.dll' (Gestito): caricato 'H:\Embedded\PROJECTS\FEZ.net micro\Gadgeteer\4.2\G400Display\G400Display\bin\Debug\le\G400Display.exe', simboli caricati.
Invalid address 22700510 and range 4 Ram Start 20000000, Ram end 20100000
Invalid address 2270057c and range 4 Ram Start 20000000, Ram end 20100000
Il thread '<Nessun nome>' (0x2) è terminato con il codice 0 (0x0).
Using mainboard GHI Electronics G400HDR version 1.2
Invalid address 227068f4 and range 4 Ram Start 20000000, Ram end 20100000
Program Started
This happens also on basic led off/on program.
Then the code seems to run normally (or at least it appears).
