Background…
Using VS 2010 Express
Windows 7 64 bit
G400-D
G400HDR
Tried with and without a T35 display attached
I have loaded the latest firmware.
This is the new package directed to by Gary (G400 Firmware and Pricing Update)
http://www.ghielectronics.com/downloads/beta/G400/
G400_Firmware_Version_4.2.10.0.zip
Copied into G400 Beta Programmer Folder - From G400 Beta Programmer(4.2.0.0)zip
config.hex
config.sig
firmware.hex
firmware.sig
I followed the 6 steps contained in How to use Programmer.txt
My G400 with T35 display attached shows on reset:
TinyBooter v4.2.0.0
G400 Build Date:
May 30 2013 14:18:41
Copyright GHI Electronics
TinyBooter GHI Version 4.2.10.0
Waiting
4.2.10.0 <-- I assume this is the firmware version that was installed
At this point I tried to Deploy and also tried Debug from Visual Studio a small test program
that does only Debug.Print(Resources.GetString(Resources.StringResources.String1));
The application does not Deploy or Debug the MFConsole application.
I once let it run for 30 minutes. Nothing… and it never deploys, fail, or time out.
From VS Output window:
------ Build started: Project: MFConsoleG400, Configuration: Debug Any CPU ------
MFConsoleG400 -> C:\Users\Will George\documents\visual studio 2010\Projects\MFConsoleG400\MFConsoleG400\bin\Debug\MFConsoleG400.exe
------ Deploy started: Project: MFConsoleG400, Configuration: Debug Any CPU ------
Side Note: Confused by this statement
Beta Firmware Update Procedure:
To update the firmware please use the FEZ Config tool found here: http://www.ghielectronics.com/support/.net-micro-framework
It fails if I try to use the Firmware Updater.
Should the new hex files be copied into
C:\Program Files (x86)\GHI Electronics\GHI Premium NETMF v4.2 SDK\G400\Firmware?
Anyway stuck in the mud here…
I’ll provide log file if needed. I’d post here but pretty long.
