Hi Guys.
I have designed a G30 based custom board. I’m using COM2 UART (Only TX and RX, No Handshake) but I need to use PA0 and PA1 as output pins. Is there any way to use them as I/O even if I have defined my COM2 Port?
Thanks in advance.
Hi Guys.
Thanks in advance.
@ malvarezdel - You should be able to use PA0 and PA1, if not used for hardware flow control.
