Hi all
i don’t understand if the g30 bootloader are the same of the old .NetMF and so for running tinyOS i have to load only the firmware (currently 0.5.0) using tera term
it is correct?
Regards
Correct. The same G30 bootloader can load both NETMF and TinyCLR (the same is also true for the G80).
ok perfect
thank you!
