G120HDR Green socket
Righto, my shiny new CP7 has turned up so time to get the soldering iron out to fix the green socket on the HDR…
Has anyone done this yet?
Is the below image correct?
@ Justin - No, you are on pin 2 need to go on pin 9, which is on the other side and down.
backlight pin on green socket is unconnected. This is connected to pin P2.21 on Rev 1.1. We suggest adding a wire between P2.21 and pin 9 on green socket so your 1.0 board will match future 1.1. This will only effect users needing to use “green” socket.
@ Michael - oops yeah i was reading the socket upside down! Cheers fella.
