Hello everyone,
I bought G120HDR board. There is blue LED on it. After update process (bootloader+firmware), LEDs light stayed dimmed. It is OK?
Hi Adam,
have you deployed an application to it post update ? Often times LEDs will stay in a high impedance state until initialised by code, so you should test further; use the pulse debug LED command and check it works correctly
You were right! I have tested βLEDβ by one purpose application and now it is OK. Thank you
