Hi Guys,
Does anybody know if the 3.5 TFT display on the G120E development board is touch sensitive?
If so, how would I go about reading it in TinyCLR OS? Is it just a case of having to read the lines via the ADC?
David
Hi Guys,
David
The display does support resistive touch. However, TinyCLR doesn’t have a resistive touch driver at the moment. You’d have to try and implement one on your own if needed.
Thanks John,
I haven’t got the board here with me at the moment but in theory can I just do something like this:
public class Touch
private readonly GpioPin _x2Pin;
private readonly GpioPin _y2Pin;
private readonly GpioPin _x1Pin;
private readonly GpioPin _y1Pin;
private readonly AdcChannel _x1Adc;
private readonly AdcChannel _y1Adc;
public Touch()
var gpioController = GpioController.GetDefault();
_x1Pin = gpioController.OpenPin(G120E.GpioPin.P0_23);
_x2Pin = gpioController.OpenPin(G120E.GpioPin.P2_23);
_y1Pin = gpioController.OpenPin(G120E.GpioPin.P0_24);
_y2Pin = gpioController.OpenPin(G120E.GpioPin.P3_31);
var adcController = AdcController.GetDefault();
_x1Adc = adcController.OpenChannel(G120E.AdcChannel.P0_23);
_y1Adc = adcController.OpenChannel(G120E.AdcChannel.P0_24);
new Thread(Monitor).Start();
private void Monitor()
//Read X
_y1Pin.SetDriveMode(GpioPinDriveMode.Input);
_y2Pin.SetDriveMode(GpioPinDriveMode.Input);
_y2Pin.Write(GpioPinValue.Low);
_x1Pin.SetDriveMode(GpioPinDriveMode.Output);
_x1Pin.Write(GpioPinValue.High);
_x2Pin.SetDriveMode(GpioPinDriveMode.Output);
_x2Pin.Write(GpioPinValue.Low);
var x = _y1Adc.ReadValue();
// Read Y
_x1Pin.SetDriveMode(GpioPinDriveMode.Input);
_x2Pin.SetDriveMode(GpioPinDriveMode.Input);
_y1Pin.SetDriveMode(GpioPinDriveMode.Output);
_y1Pin.Write(GpioPinValue.High);
_y2Pin.SetDriveMode(GpioPinDriveMode.Output);
var y = _x1Adc.ReadValue();
if (x != 0)
Debug.WriteLine(x + "," + y);
Thread.Sleep(10);
Is there an existing NetMF driver that I could port over?
It’ll be something along those lines, yes. I don’t have a test program handy at the moment.
