G120 with UDP connection using ENC28 (problem)
I have a problem with the receiving part using ENC28. I want to communicate between the PC and G120 using ENC28. The PC and the ENC28 module is both connected to a router.
When I send a UDP packet from G120 to the PC I see the message in the output box. But the G120 can’t receive from the PC when it goes the other way.
I can see the yellow LED on ENC28 is blinking when I send and that indicates the message is received (I think).
Here is some of my code on G120:
Socket client = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
IPEndPoint ep = new IPEndPoint(IPAddress.Parse(IP), port);
client.Connect(ep);
byte[] RxBuffer = new byte[20];
                if (!button1.Read() == true)
                    byte[] pakke = { 0x7f, 0x63, 0x00, 0x0a };
                    client.SendTo(pakke, ep);
                    Thread.Sleep(1000);
                    int i = client.Receive(RxBuffer);
                    for (int i = 0; i < RxBuffer.Length; i++)
                    Debug.Print(RxBuffer[i] + "-");
And the code on my PC:
UdpClient listener = new UdpClient(listenPort);
IPEndPoint groupEP = new IPEndPoint(IPAddress.Parse(IP1), listenPort);
byte[] receive_byte_array;
// if I press a button in Windows Form.
receive_byte_array = listener.Receive(ref groupEP);
            for (int i = 0; i < receive_byte_array.Length; i++)
                Console.Write(receive_byte_array[i] + "-");
That’s it… Someone who can help me?
@ Joakimj -
On PC, try with this:
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Net.Sockets;
using System.Net;
namespace Test_UDP_PC
    class Program
        static void Main(string[] args)
            Socket mySocket = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
            IPEndPoint MyServiceEndPoint = new IPEndPoint(IPAddress.Any, port);
            mySocket.Bind(MyServiceEndPoint);
                while (mySocket.Poll(200000, SelectMode.SelectRead))
                    if (mySocket.Available > 0)
                        byte[] inBuf = new byte[mySocket.Available];
                        EndPoint recEndPoint = new IPEndPoint(IPAddress.Any, 0);
                        mySocket.ReceiveFrom(inBuf, ref recEndPoint);
                        Console.WriteLine("Message From " + ((IPEndPoint)recEndPoint).Address.ToString());
                        Console.WriteLine(new string(Encoding.UTF8.GetChars(inBuf)));
                        String msg = "Hello FEZ Spider! I am PC";
                        byte[] bytesToSend = Encoding.UTF8.GetBytes(msg);
                        mySocket.SendTo(bytesToSend, bytesToSend.Length, SocketFlags.None,
                        (IPEndPoint)recEndPoint);
And here is on G120
            System.Net.Sockets.Socket socket = new System.Net.Sockets.Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
            IPEndPoint endPoint = new IPEndPoint(ip, port);
            socket.Connect(endPoint);
            String msg = "Hello PC, I am FEZ spider";
                socket.SendTo(bytesToSend, bytesToSend.Length, SocketFlags.None, endPoint);
                while (socket.Poll(2000000, SelectMode.SelectRead))
                    if (socket.Available > 0)
                        byte[] inBuf = new byte[socket.Available];
                        socket.ReceiveFrom(inBuf, ref recEndPoint);
                        if (!recEndPoint.Equals(endPoint))// Check if the received packet is from the 192.168.0.2
                            continue;
                        Debug.Print(new String(Encoding.UTF8.GetChars(inBuf)));
                Thread.Sleep(100);
And I suggest using ReceiveFrom instead of Receive
Thank you… It is working :smiley: :smiley: :smiley:
I had this problem in a week and got just more and more headache.
Now I just have to implement it in my own code…
Thank you very much again :slight_smile:
What if I just want to receive from the G120 board? I don’t want to sent packets. I tried to delete the operations where you sent (on G120). Then I deleted the receiving part on the PC.
I can’t get it worked.
Is that impossible?
Case:
I want to sent a packets from PC to G120 every second. The G120 is just reading the packets (And show them in debug mode).
It is not difficult, follow this:
//PC send every 1 sec
using System.Linq;
using System.Text;
using System.Net;
    class Program
               Thread.sleep(1000)
               // while (mySocket.Poll(200000, SelectMode.SelectRead))
                   // if (mySocket.Available > 0)
                       // mySocket.ReceiveFrom(inBuf, ref recEndPoint);
                       // Console.WriteLine("Message From " + //((IPEndPoint)recEndPoint).Address.ToString());
                        //Console.WriteLine(new string(Encoding.UTF8.GetChars(inBuf)));
And here is for g120
               // socket.SendTo(bytesToSend, bytesToSend.Length, SocketFlags.None, endPoint);
                Thread.Sleep(50);
//PC send every 1 sec - optimized
using System.Linq;
using System.Text;
using System.Net;
    class Program
					mySocket.SendTo(bytesToSend, bytesToSend.Length, SocketFlags.None, (IPEndPoint)recEndPoint);
					Thread.sleep(1000);
And on the G120 it is the same as before?
@ Joakimj -
Yest, it can be same, or you can use this
                Thread.Sleep(50);
@ Dat -
Post 6,7,9 are same, just an optimize
It is still not working. I got an error message says:
"An unhandled exception of type ‘System.Net.Sockets.SocketException’ occurred in System.dll"
at the PC side on the line:
@ Joakimj -
on PC:
 => replace by your G120 address, I think.
