From what I’ve read over the weekend the LCD_EN on the “B” socket is DataEnable. Gus might chime in here to confirm, but that was what I traced to the CPU manual running on the EMX module…
OP’s colleague here.
On the LCD connnector on the screen there’s both a DE(Data Enable) and a Display enable
So I assumed that the LCD_EN on the G120 was supposed to go to the Display Enable, because of their similar names.
But if G120 LCD_EN is indeed DE then that’s alright
Thanks for the quick reply
I am trying to activate my LCD with 800X480.
obviously I dont see anything.
With scope I see that all signals are OK.
Except LCD_DEN. Its stable on 3.3V (or floating, I dont know).
How can I activate Data enable line on top of the HSYNC and VSYNC ?
I suggest you start a separate thread with your question.
You should include a little more information. For example, what model is the LCD, how have you attached it to the Raptor, and what have you done to initialize the LCD.
