Hi everyone,
Recently, I found that my G120 did not let me deploy any code on it, so I checked the device connection with FEZConfig (v1.0.0.0). Pinging the device failed.
So I reset the device and started TinyBooter.
An update check for the device showed following information:
Loader (TinyBooter) version information:
4.2.11.1 on this computer.
4.2.10.0 on this device.
The Loader (TinyBooter) not up to date. <<<
Firmware (TinyCLR) version information:
Firmware (TinyCLR) Version: Not available.
The device is in Loader mode.
So I thought I had to reinstall the firmware. But before I could do this, I knew I had to update TinyBooter.
I followed the instructions in FEZConfig and reset the G120 in GHI Boot Loader.
The GHI Boot Loader Interface showed up in my Ports (COM & LPT) section and I was ready to go.
But the update did not start and instead showed me the message attached to this post.
Then I tried following operations:
- TinyBooter update with power supply plugged in
- TinyBooter update using G120Updater v1.0.4
- Reinstalling the USB drivers (x86)
Nothing of the above mentioned operations worked.
Is there another way to install the TinyBooter update?
Or is there a possibility to install the TinyCLR Firmware without having the latest TinyBooter?
Thanks for your help.
Regards,
S.J.
