Can some give me a sample code for touch events.
Most of the samples I found here does not compile for G120
@ microt - https://www.ghielectronics.com/docs/162/touch should be able to get you started. That touch code works on our T43 and TE35 displays.
Thanks John
I used the C# programs.
First it did not find .Run
So I had to inherit from : Application
Not sure if I am doing the right thing
Should I be using “Touch In Gadgeteer” example on G120
Sorry I thought it was obvious
public class Program : Application
private Bitmap lcd;
Program app = new Program();
[b]app.Run(); [/b]
But my questions is which example will work on G120
Gadgeteer or C#
