I have an G120 application that are divided into 4 projects (due to the limited size of a project file). Say, graphics, hardware, tools etc. stuff in different projects.
In the application options the start up object is the one and only mainproject.program.
The strange thing is that is runs perfect in Debug mode, but it does not start up if the debugger is not attached. It seems that the application simply does not start.
The main is a Console Application the three others are Class Libraries.
this has worked before. I guess that it came with the last update.
My touch GUI interface is my own.
It uses the Window class with an Image and a Bitmap - that is all.
The other windows are just the same, but as child windows.
My Projects usually consist of a ConsoleApplication and a lot of class libraries (>10).
I never had such Problems.
May be you could Switch on/off some led as 1st Thing in your app, to see if Main() gets called.
