The following code will crash the G120 and starts to output low level MCU exceptions to COM1… Remark that the encryption code is not called in this demo. So it has to do with low level init code…
using System.Security.Cryptography;
using System.Text;
namespace G120Encryption
Debug.Print("CryptoTest... actually doing nothing");
public class BlockEncryption
public byte[] Encrypt(string stringToEncrypt)
return Encrypt(Encoding.UTF8.GetBytes(stringToEncrypt));
public byte[] Encrypt(byte[] dataToEncrypt)
try
using (var rsa = new RSACryptoServiceProvider())
return RsaEncrypt(dataToEncrypt, rsa.ExportParameters(false));
catch (ArgumentNullException)
Debug.Print("Encryption failed");
return null;
public byte[] DecryptByteArray(byte[] dataToDecrypt)
return RsaDecrypt(dataToDecrypt, rsa.ExportParameters(true));
private static byte[] RsaEncrypt(byte[] dataToEncrypt, RSAParameters rsaKeyInfo)
try
byte[] encryptedData;
rsa.ImportParameters(rsaKeyInfo);
encryptedData = rsa.Encrypt(dataToEncrypt);
return encryptedData;
catch (CryptographicException e)
Debug.Print(e.Message);
return null;
private static byte[] RsaDecrypt(byte[] dataToDecrypt, RSAParameters rsaKeyInfo)
byte[] decryptedData = null;
try
decryptedData = rsa.Decrypt(dataToDecrypt);
Debug.Print(e.ToString());
return decryptedData;
