Setting High or Low does not change the port state of P1_23 and P1_24.
Outputport does not raise an exception - it jut do nothing - like no connection.
But, can measure a connection directly from the pins to transistors for LEDs on my PCB.
I have used the G120 with a LCD on the same pins - that works fine.
So, I was thinking - does the LCD part of the firmware lockup these pins, so they cannot be used for PGIO?
I did this today, used 8 display IO’s in the 2_xx range for interrupt enabled inputs and 8 display IO’s in the 1_xx range as output’s, worked like a train.
What’s the complete setup and code?
