G120 Interrupt Exception thrown
I’m currently trying to port a working project from Cerb 40 II to G120 for production samples. I found that the interrupt “InterruptEdgeLevelHigh” and “InterruptEdgeLevelLow” throw exceptions. This is not a show stopper as I can use other trigger options except these two. However, just out of curiosity if this something GHI intentional disable or it just something wrong?
I’ve a short test code below that throw exception and the screen capture.
using GHI.Pins;
namespace TestInterrupt
static InterruptPort int_pin = new InterruptPort(GHI.Pins.G120.P0_5, true, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeLevelLow);
        int_pin.OnInterrupt += new NativeEventHandler(int_pin_OnInterrupt);
    static void int_pin_OnInterrupt(uint data1, uint data2, DateTime time)
        int_pin.ClearInterrupt();
        Debug.Print("Interrupted....");
The level interrupts have never been implemented. Edge interrupts only.
Thanks Mike
