I am not able to create an application deployment file with MFDeploy or the GHI .net configuration tool V 0.0.3
MFdeploy (4.2) returns an error message “Device has old or unsupported” configuration (see attached image)
While GHI configuration tool creates a file with zero length…
I tried different possibilities:
- erased all memory using mfdeploy
- re-flashed the device (Cobra II) with firmware 4.2.10.1 and loaded the application.
Nothings seems to help, @ GHI can you please advice?
@ RobvanSchelven -
I just tried with FEZ Config tool 013,
- Deploy PhilM’s code about ENC28 problem by VS2010.
- Then use FEZ Config tool 013 to extract out a HEX file.
- Deploy that Hex file by FEZ tool again
It is OK.
@ Dat - Thanks, maybe i use an outdated config tool (0.0.3) will download and test with 0.1.3
Unfortunately V.0.1.3 gives the same result as V 0.0.3 The file that it creates is zero length. I am using the WINUSB driver. Do you know if that could be of influence?
Update… this seems to work…
VS -> deploy application… (DON’T RUN IT)
Configuration tool -> create HEX File
Creating a HEX file when the application has run ones will fail and result in a null length hex file.
Maybe because i use RLP??
