G120 and USB
Could a g120 be connected via usb to a computer and also a camera? I am wondering if I can get rid of the hub I was using when I had the computer coming in and then talking to a camera and the chipworkx board.
You can connect both but it won’t be a hub exactly. Your pc will not see a camera but g120
Are there any chips you would recommend that can act as a hub that have been used before?
I saw a Cypress CY7C65630-56LFXA but wasn’t sure if there were drivers needed/available.
Why not just use a hub chip? What is your application?
I am looking into hub chips now actually. The Cypress chip is a hub chip. I guess i don’t fully understand how they work. I thought i would still need a driver but it looks like once i had the chip and related circuitry there, it woudl act like a regular hub and there wouldn’t be a driver needed from the ghi board.
I just need to find one that is rated up to 85 C at this point.
Look inside any USB hub, it is just a chip, there is no software involved.
