The user manual (March 9, 2015) say’s the G120 has 10 bit analogs (0-1023).
AnalogInput.ReadRaw() is returning values from 0-4095, indicating the G120 has 12 bit analogs.
I assume the user manual is incorrect, right?
btw: My custom board has circuitry connecting the analog inputs to sensors that are 4-20mA, when I max the sensor out (20mA) I am seeing the digital analog count value = 4095
Yes Brett… I fully understand how analogs work!
My circuitry converts current to volts, where 20mA = 3.3V.
At 3.3V on the analog pin, I am seeing a count = 4095.
The manual says the analogs are 10bit (0-1023)…but I am seeing 4095 (12bit).
I am asking for verification that the manual is incorrect?
12-bit Analog-to-Digital Converter (ADC) with input multiplexing among eight pins,
conversion rates up to 400 kHz, and multiple result registers.
The 12-bit ADC can be used with the GPDMA controller.
10-bit Digital-to-Analog Converter (DAC) with dedicated conversion timer and DMA
support
